There is some way of reset the router to the default values but without then it is necessary to tune in for serial him an ip adds ?
You can reset your router configuration by typing following command:
/system reset
But this will delete ip addresses also. For this moment there is no way to reset router without loosing ip addresses, too.
is it possible to have interfaces enabled after reset? Now it’s necessary to connect to serial port (which means openning of outdoor box as in our case). If we had the Ethernet interface enabled by default it would be much easier to access via mac-telnet, which is really great tool.
it will be possible in 2.9 version
That is GREAT news - a radio up a mast with ethernet but no RS232 connection is the ultimate example -
Look forward to seeing the next 2.9 version!
That’s already made in 2.9beta8
