I want to reset the user counters. there is a reset all counters button. even when i open a single hotspot user the button says reset all counters. i have clicked by mistake this button twice loosing all the user counters. i need to know how can i reset a single user, the simplest way?
/ip hotspot user reset-counters “username”
does the command above function right or will it reset all counters?
/ip hotspot user reset-counters [find name="username"]
Or any of the other available fields that you can set information for, like comments, passwords, mac-address, etc. For example if you use comment, it will reset any counter with that comment you search for. Use [find] to return all users and reset the counters.
