Reset default IP address to a RB-450G Mini router
I was told my 3 routers were cleared and set to a default IP address. Can someone help me identify:
A: What is the default IP address
B: If it ISN’T at default, what are the procedures to default it
C: If I cannot default it to a predetermined IP address, how can I find out what IP address is assigned in the router
Thanks all for your support
a: on that router, I believe it is DHCP on the WAN interface (ether1), and 192.168.88.1/24 on the LAN interface (ether2). You can look it up on the box it shipped in, or reset in hardware as described in b) and then access via serial console and look at IP configuration.
b: “/system reset-configuration” if you can access it (IP, MAC, or serial console), or follow the instructions for a software reset by shorting the reset hole as described in the device’s hardware manual (http://routerboard.com/pricelist/download_file.php?file_id=143).
c: if you’re unsure it’s always best to use the serial console.
