Reset for RB-2011L-IN ??
Hi
Instructions for RB-2011L-IN states:
Release	the	button	when	green	LED	starts	flashing,	to	reset	RouterOS	configuration.	To	not	load	backup	bootloader,
you	can	start	holding	the	button	after	power	is	already	applied
I’m sorry but the green LED never starts blinking. It goes ON when I apply power and then off 3 seconds later and that’s it !! Is there an error in documentation ?
Vincèn
Instruction here is correct, if there is problem with reset button, you can also use CLI to reset the board: /system reset-configuration and if this is not possible, use jumper hole to erease configuration :
http://wiki.mikrotik.com/wiki/Manual:Reset#Jumper_hole_reset
If the reset button is working correctly, then the LED should start to blink after ~5 sec.
