Reset Mikrotik Cube Pro after setting wrong IP
Hi all,
I’ve a Cube Pro 60 ac and set a wrong ip (10.150.150.0/24) under IP → Addresses. WinBox finds it with IP 0.0.0.0 under neighbours, but i cant connect: Could not connect.
I’ve resetted the device as described here https://help.mikrotik.com/docs/display/UM/Wireless+Wire+Cube+Pro%2C+Cube+60Pro+ac but it is not pingable at 192.168.88.1.
How I can reset the device correctly?
Thanks!
Try Winbox in MAC mode. https://help.mikrotik.com/docs/display/ROS/Winbox
@BartosP i’ve tried WinBox with wine under MacOS and error message is “Could not connect” But it will be found in Neughbours list with IP 0.0.0.0 and correct MAC addreess
Why the reset does not work? 30 Seconds after reset all LEDs are blinking two times and the device reboots, but no factory settings are loaded. Firmware ist 6.49.8
When you connect to the MAC address (click on it), you can see if it has been reset or not.
Some devices do not get the 192.168.88.1 IP on reset, and you need to set an IP manually or configure DHCP client.
