Hi, I have a problem. It is impossible to reset the Mikrotik Metal 5shpn. On winbox I get an ip address 0.0.0.0.
I try to access the MAC address but it is impossible to enter.
I try to reset the Bullet but I can not find the address 192.168.88.1. The address is always 0.0.0.0.
How do I reset the Metal 5shpn.
thanks
Cut off the power from the metal.
Press and hold the button while you turn on the power.
Press and hold the button for 15 seconds and release.
This should reset the metal
Is your problem solved?
I have a MikroTik Metal G-52SHPacn…I have the same problem and I try this…and working…(excuse me…I don´t write very well in English, I’am from Cuba)
Hi, unplug device from power, press and hold the button right after applying power and wait until the USER LED starts flashing. Now release the button to clear configuration.
