Reset n aurorun dot rsc not working well with new bugfixes ros
Since long time ago i always use reset config n autorun file.rsc configurations. Its always working normally until 6.37.5. I skip 6.38.x. I got the problem in 6.39.3 n 6.40.6. Havent test 6.40.7 yet.
The problem is: only few first lines applied. The rest lines below skipped. This problem very annoying, make me must travel for 5 hours to remote location for reprogram mikrotik router. The file.rsc working normally when copy paste to winbox terminal. No error at all. Tested reset n autorun file.rsc with 6.37.5 n its working! No error! So i dont think the problem came from my file.rsc, but the new ros. Please fix it. Thanks.
I am using auto.rsc with the latest firmware on >100 devices and have no issues at all. Are you sure your file is ok?
