Reset Not Working RBD52G-5HacD2HnD
Dear folks,
Please urgently advise on how to go about resetting the mikrotik to factory default with username as admin and no password.
This is a brand new router, I was able to log into it the first time via winbox but after a reset (switched off, hold the res button and power in) USR flashes and stopped, I got IP address of 192.168.101.1
I have repeated necessary steps to get this router to reset so that I can use the 192.168.88.1 default without password to log back but to no avail.
Anyone with this issue or advise on how to resolve this.
thank you
I have a similar problem with brand new RB951 with routers 6.49.13: the router correctly provides a DHCP address in the subnet 192.168.88.0/24 but when I log in with credentials “admin/no password” it does not allow me to access, both with Winbox and SSH.
Cannot sat specifically about the ac2, but newish Mikrotik routers come with a user admin and a “random” password preset.
The password is (un-[1]) readable both on a sticker on the device and on a label attached to the instructions.
AFAIK the reset should get back to those values.
[1] printed very small and with the usual ambiguous characters:
https://gajus.com/blog/avoiding-visually-ambiguous-characters-in-ids
not easy to distinguish
My fault,
the label on the back of the product shows, in very small print, the password to use …
