Reset Optins For MicroTik Routerboard
Hello to everyone
I’m new here if you please help me
I want to reset Mikrotik Router configuration without remove user-manager Hot-spot setting(without delete it’s files)
is it possible?
Thank you
I don’t think so, You may backup your desired data and file (hotspot and UM) and then reset your config.
Hi bro…
how can i backup only from usermanager and Hot spot options not the complete one?
