Reset RB433GL
I have 2 off RB433GL’s each fitted with 2 off Ubiquity SR71-15’s.
The RB433GL’s have version 2.38 firmware.
I have tried to reset the configuration of the 433’s using:-
/system reset-configuration
This has reset the 433’s but the radio boards still appear to have some settings in them.
How do I clear out the settings in the radio boards? or is it unnecessary.
David.
does this help: Interface wireless reset-configuration
Thank you for your help, that seems to have cleared the configuration, now to try for Nsteme dual…
I had to go up 2 levels, if that’s the correct term to /Interface wireless then type in reset-configuration then it asked which radio I wanted to reset.
David.
Write: interface wireless print
To check which wlan you want to reset: 0,1,2…
