reset rb750g
I had to reset the rb750g as I locked myself out by disabling the ethernet interface I was locally connected to.
Now, I don’t seem to have the same ethernet ports. i.e. 1-gateway, 2 master ethernet, 3-slave ethernet, 4 slave ethernet.
I reloaded routerOS 4.9 but can’t seem to see the same default config.
Router works as original, but I just don’t have the same topology as factory.
what do you mean, what is different after reset?
Everything seems to working fine. I recollect seeing different interface names, before the reset.
1st port was, "gateway ether1", now it's simply ether1. 2nd port was "master ether2, now simply ether2. 3rd port was slave? ether3. 4th port was slave ether4. 5th port was slave ether5.
I thought that is what was the original factory settiongs? Correct me if I 'm wrong.
[admin@MikroTik] /interface> export
jan/01/1970 16:06:11 by RouterOS 4.9
software id = GVT4-JHYE
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5E:A4:5A
master-port=none mtu=1500 name=ether1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5E:A4:5B
master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5E:A4:5C
master-port=none mtu=1500 name=ether3 speed=100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5E:A4:5D
master-port=none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment=
"" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:5E:A4:5E
master-port=none mtu=1500 name=ether5 speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
set default authentication-types="" eap-methods=passthrough group-ciphers=""
group-key-update=5m interim-update=0s management-protection=disabled
management-protection-key="" mode=none name=default
radius-eap-accounting=no radius-mac-accounting=no
radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0="" static-key-1="" static-key-2="" static-key-3=""
static-sta-private-algo=none static-sta-private-key=""
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key=""
wpa2-pre-shared-key=""
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
set (unknown) vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:D7:FE:E4:10:2D
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
This pic is of the unit after reset.
Is this correct?
Again, everything seems to be working fine.
Just wondering if I lost any funtionality.
Thanks again
Have you used /system reset-configuration or /system reset-configuration no-defaults=yes?
Do you have any backup file at /file?
Thanks,
/system reset-configuration did it.
Don’t think I’ll be playing with the beta webfig and disabling etho port 3 again.
That got it back to familiar settings.
:sunglasses:
