Reset router and no longer able to use it
I reset my router and now it doesn’t work. Can’t access it from 192.168.88.1. I think the last update I performed on the router was a beta build but that was over a month ago. Is there a proper way to access the router again? Also the wireless no longer shows up. The light will flash once when powering up.
MikroTik hAP AC RouterBoard, Triple Chain Access Point 802.11ac (RB962UiGS-5HacT2HnT-US)
That’s what it was called on Amazon.
If you reset it completely, it’s possible that it now has no config at all, so no IP address. But you can use WinBox to connect to it using MAC address. You should see it on Neighbors tab in WinBox (you may need to allow winbox.exe in firewall first).
You should not access it “from” IP address 192.168.88.1, as that will be the router address.
Then also make sure you try and access the router from ports 2 and up, as ether 1 will have firewall rules as per default config preventing access to device
