dannym
October 19, 2013, 5:05pm
1
hello
I’ve got this router mentioned on the topic title but I cannot reset it.
Tried http://klseet.com/index.php/mikrotik/mikrotik-rb750-750g/hard-reset-factory-default
and http://forum.mikrotik.com/t/impressions-review-of-the-2011uas-2hnd-in/62505/1 but I have not luck. So ask for help. How do I can reset my board? Thanks
dannym
March 16, 2014, 4:22pm
3
Now .some months later everything everything works perfectly. Thanks to you. I forgot to post a reply.
dannym
February 16, 2016, 7:38pm
4
Ive got a problem. My board is with 6.32.3 OS version, but some menu butons and functions missing
I tried to update through the menu, also tried with netinstall but nothings happens. Any ideas ?
lambert
February 16, 2016, 9:17pm
5
Did you disable the advanced-routing package?
dannym
February 16, 2016, 9:27pm
6
a shot.
Now I would like to update RB OS to next bugfix release but smthng wrong there. I cant install a new version through netinstall.
lambert
February 16, 2016, 9:43pm
7
Looks like you installed individual packages rather than the bundle package. I’d download the 6.32.4 bundle http://download2.mikrotik.com/routeros/6.32.4/routeros-mipsbe-6.32.4.npk , not the extra/all packages zip file from the download page, ftp/scp/drag&drop it onto the Mikrotik and reboot.
dannym
February 19, 2016, 6:49pm
8
I tried this before try reinstall with Netinstall.
Since my first post here Ive been reinstalled via Netinstall may be arround 10 times.
lambert
February 19, 2016, 11:39pm
9
jarda
February 20, 2016, 6:52am
10
First. What functions are you missing? Second. Have, or tried check for updates and automatic download and install? What it did? Paste a screenshot…
