Hi
I have RB333 with MT ver. 6.28 and two card AR92xx. When I try do bandwidth test direction ‘send’ then roterboard is reboot with info in log:
09:48:18 system,error,critical router rebooted without proper shutdown, probably p ower outage 09:48:51 interface,info eoip-tunnel-bosa link up
But test receive is ok.
Maybe someone know what’s the problem.
Thanks Dario
Try removing both wlan cards, then perform the same test but this time to 127.0.0.1 If it still happens, then I suspect you have a problem routerboard.
What kind/type/voltage/watts power supply are you using?
North Idaho Tom Jones
Power supply was PoE 18V 700mA, to day replace by PoE 24V 750mA First few tests was OK, will see tomorrow how it will work.
Maybe it is time to swap the power adapter or the capacitors on the board.
