As you mention “losing” access, it implies you still have it. If so, you should be able reset the machine to default configuration using a command rather than by power cycling it and pressing the reset button, which means you could prepare in advance a configuration script with the required configuration allowing remote access and use the /system/reset-configuration command with the run-after-reset parameter to run the script at the first boot after the configuration reset (look also at the keep-users and no-defaults parameters). But there are some surprises (you have to delay execution of the script for some time as e.g. it can be spawned before all the network interfaces have been detected and initialized), so it is very useful to debug it first using some locally accessible Mikrotik device, like e.g. a CHR running on any virtualisation platform you have at hand. You will have just one attempt in the real case.
I would think a whale eating an apple is really close to shore and will most likely end up being grounded
My underlying meaning with my response was that it can not be done out of the box without jumping through some hoops and careful planning/testing.
Which gets backed up by the other responses.
would suggest this approach too.
test this on a local MT first and examine if the default configuration can be altered as far as you need to access it remotely.
e.g.
setup a firewall input allow rule on top specific to your remote accessing location
OR
configure a “default” wireguard tunnel for “quasi zero configured” routers
…this could even be fleshed out to your own “SD-WAN” or better, “(semi)zero touch deploy” solution (;
Maybe the meaning is “you can’t use netinstall to install a remote device”, if so.
Otherwise it seems “You can’t use the netinstall remote control”…
FALSE: if you have the right devices available and connected properly.
It is not the first time I do netinstall remotely from other RouterBOARD…
anyway, yours is useless note, since my comment was about whether he was trying to clean the router from something “dirty”…
It is not enough to reset the RouterBOARD to factory default.
However, by not explaining the reason, he doesn’t get the right hint.
Make sure that this file defines an IP-address for ether1 (or whatever you use for remote access) including default routing and what else thats needed.
Also since Mikrotik changed default password to one put on the sticker at the bottom of the unit you might want to keep the current users with keep-users=yes otherwise to completely start over I would suggest to use keep-users=no.
You getting realize what the difference between “home-grade” vs “telco-grade” hardware.
Thats the reason why professional equipment has dedicated OOB port ( OpenBMC, Redfish, IPMI, … ).
You cannot do this without OOB (Out-of-band management) interface which has separate data and control plane.
Hogwash, of course. When you have a dedicated OOB port, you need remote access to that anyway.
And when that is a prerequisite, you can do it with MikroTik equipment too. Some routers have RS232, you can cross-connect that between two routers and access one router from the other, even after factory reset.
Similar options are possible when the routers are connected via an ethernet port (there is MAC-level access), you can even netinstall one router from the other when you have interconnected the correct port.
That it is possible with “professional equipment” is only true when there is a professional admin who understands what has to be prepared.
If you have other mikrotiks or any the same ethernet ports as the router in question.
(And assuming when you reset the mikrotik it doesn’t disconnect your access to those other mikrotiks)
You will likely be able to login to it from those other mikrotiks using mac telnet.
It seems there is also a mac telnet client for linux.
