Reset the dude client to the default settings every time it starts
Good afternoon. After the dude client is updated to version 6.41.4, the connection settings are not saved on the windows client. Every time you start the program, you have to enter everything with your hands? because the connection settings are set by default. Tell me what could be the problem?
Even when the client closes to the PC with windows 10 x64, the client hangs constantly and it is necessary to shoot the task.
