reset to default config problem
router 4 series had a reset to default config problem which i could not get past. everytime i made a change tafter reboot, the router was back to its original config. Decided to reinstall to v3.17 after netinstall to get rid of a reset to default configuration problem, router 4 series v3.17 will not allow login any suggestions to rectify this?
maybe remove ‘Reset Configuration’ jumper?
