I have a Lora Mikrotik WAP LR8 kit gateway that was working until I had to do a reset because I wanted to delete its configuration.
The issue is that after I did the reset it has stopped working. Following the instructions you have to disconnect the equipment from the power and then press the reset button, connect the power and release the reset button after 5 seconds.
I repeated the process several times but I can not get the equipment to work again, that is, the power light appears green, but the wifi light appears off and the wifi network “mikrotik” is not detected from the pc or mobile.
