Reset Wireguard Peer Counters
Hi!
There are counters for sent/received KiB for every Wireguard peer, but:
How can I reset these counters?
I did not find any option.
Thank you and best wishes
Stril
This would be nice.
Right now as workaround, I delete the peer, and then undo last change so the peer comes back with 0 counters
Disable / enable of peer does the same thing.
Much safer then delete, I would think ?
Does not work for me
