Good afternoon
I a set of pre configured Wireless Wire Cube Pro. From my understanding they should act like a cable with their default config. I am afraid past me made some changes on them. If I reset them; will the default config (pre configured) come back? Or will they be blanco?
is “blanco” only if you select “no default config”
remember to check before reset if the sticks with password still are present on case an readable
