reset
i have mikrotik router which for wireless connection as base,but have forgoting my password and then tr to reset but stil show old configuration,pl help me out the way i can reset .thanks
rotimi adekunle
You cant Reset to default… you must know the password… send mail to support@mikrotik.com perhaps they can help you…
There is no way to recover the admin password short of a reinstall.
Oh.. fatal mistake…
The way is only reinstall system …
Regards
