I’ve often read around here and also I think I have seen support say to reset configuration and upgrade router in case of a problem.
I have always wondered exactly what this means and if it is needed I have questions:
1/ What kind of problems can this solve and what should I look for?
2/ If you have to reset it can you re apply a backup file or import an exported config or do they mean literally config it from scratch?
