I recently purchased a Netmetal AX. When it arrived it was not broadcasting any SSID, and the factory password on it’s labels didn’t work (I tried replacing 0 and O, and 5 and S). Running netboot and fully clearing the configuration worked to remove the password, and get it to broadcast a SSID. The problem is that now whenever I reset the device, it returns to the initial (broken) configuration, requiring the netboot fix. Is there any approved way of overwriting the factory config? Has anyone else encountered this issue? It looks for all the world like there was simply a step missed in the configuration of the device in the factory.
