Resetting Webfig
Using 5.14, is there a way to reset only Webfig? When I log in, I just get a blank grey screen. I must have messed up a template configuration or something.
The web fig is actually used to configure and gain access toward the hardware and what you actually keep up and bind with the interface will also take effect in your hardware. On that note, you just have to reset it altogether if you really have to tinker and change a few of the settings on your hardware.
If you are not too confident with that, I suggest that you first do a backup of all the current settings just to make sure that you will have something to get back with.
If you edited the Webfig skin and messed up, delete the JSON file in the root folder via FTP, it should bring back the default skin
http://forum.mikrotik.com/t/webfig-skin-error/55158/1
I’ve reported same problem few days ago, still no answer :frowning:
Regards,
Awesome - that worked. Thanks.
