[RESOLVED] How to fix mikrotik login failed with radius - added "require-message-auth" option on v7.15+ ?
I setup on mikrotik with new firmware v.7.15.1.
I try to login hotspot with external radius but login failed
I checked on changeslog I found new option below
RouterOS v7.15+
*) radius - added “require-message-auth” option that requires “Message-Authenticator” in received Access-Accept/Challenge/Reject messages;
*) radius - include “Message-Authenticator” in any RADIUS communication messages besides accounting for all services;
My radius server on https://www.cloud-hotspot.com is not reply Message-Authenticator on access-accept.
Mikrotik rejects user login.
Please advice me how to resolve this.
Is any config to disable “require-message-auth” option ?
What I need to config on my radius to reply Message-Authenticator to mikrotik ?
Thank in advance
Chuan
Yes - set require-message-auth (in the server definition in the RADIUS menu) to ‘none’.
Thank you for your reply.
problem solved
Hi, I’m very glad you solved the problem, but I and the forum would be so much happier
if you also mark your case in this forum as solved.
See the pictures below.
Where you click on the following places on the thread that solved your problem.
So the AI can take over and know what the problems are with the respective solution.
At board style: Canvas
At board style: prosilver
Done
