[Resolved] Proxylizer is discontinued ?
I have read:
Note: MikroTik has discontinued the Proxylizer project, it will no longer receive updates, and technical support will not be available
is true ? :frowning:
there is an alternative ?
Tanks
any Syslog program will work as an alternative. MikroTik webproxy logs use standard format, so any program like this will work http://www.kiwisyslog.com/
There is a good syslog linux debian-based ?
Tanks
there are really many, you need to google for something like that.
Hello, I would tell you that you have available, so you can implement it and evaluate it, work called PartyLog2. It contains a frontend called Garylog and is based in rsyslog.
Just download the vm, I ride a VMWare ESX / ESXi and run.
Donwnload: http://sourceforge.net/projects/partylog2/
TurnkeyLinux Project: http://www.turnkeylinux.org/forum/general/20110616/syslog-server-appliance-request-features-rff
You access the console and edit the file /etc/rsyslog.conf
Looking for the line that says:
#Provides UDP syslog reception
#$MODLOAD imudp
#$UDPServerRun 514
To be as follows
$MODLOAD imudp
$UDPServerRun $ 514
Save the changes and restart the service with the following command
service rsyslog restart
Finally configure the logging of Routerboard to point to the IP of PartyLog2 using port 514.
I hope it's useful.
Spanish:
Hola, quisiera contarte que tienes a disposición, para que puedas implementarlo y evaluarlo, el trabajo llamado PartyLog2.
Contiene un frontend llamado Garylog y está basado en rsyslog.
Solamente descarga la vm, lo montas en VMWare ESX/ESXi y la ejecutas.
Descarga: http://sourceforge.net/projects/partylog2/
Proyecto TurnkeyLinux: http://www.turnkeylinux.org/forum/general/20110616/syslog-server-appliance-request-features-rff
Para que comience a recibir información desde tu mikrotik, primero tienes que habilitar el puerto de escucha
Accedes a la consola y editas el archivo /etc/rsyslog.conf
Buscas la línea que dice:
provides UDP syslog reception
#$ModLoad imudp
#$UDPServerRun 514
Para que quede de la siguiente manera
$ModLoad imudp
$UDPServerRun 514
Guardas los cambios y reinicias el servicio con el siguiente comando
Por último configuras el loggin de RouterBoard para que apunte a la IP de PartyLog2 utilizando el puerto 514.
Espero que sea de utilidad.
