[Resolved] Share file Lan eth1 from Lan wireless
My routerborad is Rb433AH with RouterOs 5.11
I have 2 Lan:
Lan eth1 (cable) address 192.168.1.x
Lan vLan1 (wireless) address 192.168.2.x
It is possible to share file of lan eth1 from lan vLan1 ?
It is possible to see/modify the resource shared of lan eth1 from lan vLan1 ?
Tanks for your help
As long as both machines exchanging the shared files have the ip address of the interface they are connected to set as thier default gateway you will not have to modify your settings at all. You will have to manually navigate to the share via IP address.
I created the “bridge” with port eth1 and vLan1
In the ip address, i have create only one address 192.168.1.x on bridge
Tanks
