Resolved, ~~ strange problem, the hotspot can't work any more, please help
I have to reset my router (RB951Ui) in today with basic configuration, but strange problem is the hotspot page can't work any more, the IE say "404 error, can't find the page", it's happened when I open any outside website, but hotspot on the gateway IP address "172.16.0.1" is working
below is my configuration, sincerely thanks
feb/17/2015 08:14:05 by RouterOS 6.5
software id = AP9J-1DL6
add admin-mac=4C:5E:0C:31:E2:EB auto-mac=no l2mtu=1598 name=bridge-local protocol-mode=rstp
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=ether5-slave-local
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-gateway name="\D6\D0\B9\FA\C1\AA\CD\A8" password= user=
/ip neighbor discovery
set ether1-gateway discover=no
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=82128388 supplicant-identity="" wpa-pre-shared-key=82128388
wpa2-pre-shared-key=82128388
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=indoors ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge name=
Home security-profile=82128388 ssid=Home
add disabled=no l2mtu=2290 mac-address=4E:5E:0C:31:E2:EF master-interface=Home name="Home Free" ssid="Home Free" wds-cost-range=0 wds-default-cost=0
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d
add name=192.168.88.0-dhcp ranges=192.168.88.10-192.168.88.254
add name=172.16.0.0-dhcp ranges=172.16.0.100-172.16.0.150
add address-pool=192.168.88.0-dhcp disabled=no interface=bridge-local name=default
add address-pool=172.16.0.0-dhcp disabled=no interface="Home Free" name=server1
add address-pool=172.16.0.0-dhcp idle-timeout=none keepalive-timeout=2m mac-cookie-timeout=3d name="172.16.0.0 uprof1" transparent-proxy=yes
/ip hotspot profile
add login-by=http-chap,trial name="172.16.0.0 hsprof1" trial-user-profile="172.16.0.0 uprof1"
/ip hotspot
add address-pool=172.16.0.0-dhcp disabled=no idle-timeout=none interface="Home Free" name=server1 profile="172.16.0.0 hsprof1"
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=Home
add address=192.168.88.1/24 comment="default configuration" interface=bridge-local network=192.168.88.0
add address=172.16.0.1/24 interface="Home Free" network=172.16.0.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
add address=172.16.0.0/24 dns-server=119.6.6.6 gateway=172.16.0.1
add address=192.168.88.0/24 comment="default configuration" dns-server=119.6.6.6 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=masquerade chain=srcnat comment="default configuration"
/ip service
set www port=800
/system leds
set 0 interface=Home
/system ntp client
set enabled=yes mode=unicast primary-ntp=202.118.1.81 secondary-ntp=202.112.10.36
I’m forgot to post the hotspot working on gateway when I add it in walled garden IP list. but can’t work when I try to open any outside website.
I think something wrong/missing in my configuration, but I can’t find it.
did you change something in the hotspot html files? renaming, moving, deleting?
No, I try to reset all of my router with default settings, and hotspot folder created by system automatically.
problem resolved, I have type the wrong DNS, now change the DNS server to local gateway in DHCP server, and it’s working, Thanks everyone.
