resource monitor for cpu and ram usage on 3.0
I know many people have said this but feel like I have to rewrite again to remind the MT coders. There should be a resource monitor of cpu and ram on the 3.0, so when there is cpu 100% we can check which package is doing that so we can disable that package. mostly I can not even get a support rif file because of 100% cpu usage.
and to the others which are complaing about the new 3.0. help the MT coders with sending support rif. so they can solve the problem in the next versions. not just complain.
Yes ! I agree. I need this future, too.
I have same problem with CPU !
IMHO it is not so simple - there must by programs that run on several packages at one.
I know, but for testing sometimes suffice block of packages. When I find out, that system package load CPU on 100% - I know what I must test.
