REST API basic help
Trying to get a response from a hEX S (7.1beta4) installed from a Raspberry Pi.
Using:
$ curl -k -u admin: https://10.0.0.210/rest/system/resource
(https://help.mikrotik.com/docs/display/ROS/REST+API)
www-ssl enabled / all firewalls off / login tcp traffic to 443 / user: admin / password: none
This is the response I’m getting from the Pi:
curl: (35) error:14094410:SSL routines:ssl3_read_bytes:sslv3 alert handshake failure
Logs:
10:22:27 firewall,info input: in:bridge out:(unknown 0), src-mac b8:27:eb:0e:03:f4, proto TCP (SYN), 10.0.0.81:52228->10.0.0.210:443, len 60
10:22:27 firewall,info input: in:bridge out:(unknown 0), src-mac b8:27:eb:0e:03:f4, proto TCP (ACK), 10.0.0.81:52228->10.0.0.210:443, len 52
10:22:27 firewall,info input: in:bridge out:(unknown 0), src-mac b8:27:eb:0e:03:f4, proto TCP (ACK,PSH), 10.0.0.81:52228->10.0.0.210:443, len 569
10:22:27 firewall,info input: in:bridge out:(unknown 0), src-mac b8:27:eb:0e:03:f4, proto TCP (ACK,FIN), 10.0.0.81:52228->10.0.0.210:443, len 52
Any assistance would be appreciated. TIA.
Handshake can fail if there is a problem with certificate chain. Have you set certificate for www-ssl service on the router and have you imported CA certificate (used to sing the www-ssl service certificate) on the client device?
Hi, I just tested this and it works as intended. You just need to generate and sign server certificate. This is how I do it (replace “your.server.url” if you like, it works anyway and is good enough for testing purposes):
/certificate
add name=ca-template days-valid=3650 common-name=your.server.url key-usage=key-cert-sign,crl-sign
add name=server-template days-valid=3650 common-name=your.server.url
/certificate
sign ca-template name=root-ca
:delay 3s
sign ca=root-ca server-template name=server
:delay 3s
/certificate
set root-ca trusted=yes
set server trusted=yes
/ip service
set www-ssl certificate=server disabled=no
Thanks, see my error now.
Is there way to do it using HTTP Basic Auth?
Thank you che!
what is your.server.url? can you please gave me example?
you need one example for understand the example?
