REST API: PowerShell running a script remotely from windows
I wrote a powershell script that runs a script on the RouterOS device remotely via REST API.
https://gist.github.com/elico/9110bc2a7eab12b9e65a1c1b3e4f8c69
add-type @"
    using System.Net;
    using System.Security.Cryptography.X509Certificates;
    public class TrustAllCertsPolicy : ICertificatePolicy {
        public bool CheckValidationResult(
            ServicePoint srvPoint, X509Certificate certificate,
            WebRequest request, int certificateProblem) {
            return true;
[System.Net.ServicePointManager]::CertificatePolicy = New-Object TrustAllCertsPolicy
$user = 'admin'
$pass = '1234'
$pair = "$($user):$($pass)"
$encodedCreds = [System.Convert]::ToBase64String([System.Text.Encoding]::ASCII.GetBytes($pair))
$basicAuthValue = "Basic $encodedCreds"
$Headers = @{
    Authorization = $basicAuthValue
$body = @{
    ".id" = "switchSimCard"
$routerOSHost = "192.168.88.1"
$url = "https://$routerOSHOST/rest/system/script/run"
Invoke-WebRequest -Uri $url  -Body ($body|ConvertTo-Json) -Headers $Headers -Method POST -ContentType application/json
Thank you for sharing this code-snippet. I added the feature to either launch a script or a single command and did some minor changes:
.Synopsis
    Invoke-MikrotikRestAPI.ps1 uses Mikrotik's RouterOS-RestAPI to remotely trigger actions.
.EXAMPLES
    Invoke-MikrotikRestAPI.ps1 -RouterIP 192.168.88.1 -User admin -Password "MyPassword" -ExecutionMode Command -Data "/log/info test"
    Invoke-MikrotikRestAPI.ps1 -RouterIP 192.168.88.1 -User admin -Password "MyPassword" -ExecutionMode Script  -Data "MyScriptName"
Param (
    [Parameter(Mandatory = $true)][String]$RouterIP,
    [Parameter(Mandatory = $true)][String]$User,
    [Parameter(Mandatory = $true)][String]$Password,
    [Parameter(Mandatory = $true)][String]$Data,
    [ValidateSet("Script","Command")]$ExecutionMode="Command"
add-type @"
    using System.Net;
        public bool CheckValidationResult(ServicePoint srvPoint, X509Certificate certificate, WebRequest request, int certificateProblem) {
            return true;
$encodedCreds = [System.Convert]::ToBase64String([System.Text.Encoding]::ASCII.GetBytes("$($User):$($Password)"))
$Headers = @{Authorization = "Basic $encodedCreds"}
$ErrorActionPreference = "SilentlyContinue"
$tc = [System.Net.Sockets.TcpClient]::new()
$tc.Connect($RouterIP, 443)
$ErrorActionPreference = "Continue"
if ($tc.Connected) {
    if ($ExecutionMode -eq "Script") {
        $body = @{".id" = $Data}
        Invoke-WebRequest -Uri "http://$RouterIP/rest/system/script/run" -Body ($body|ConvertTo-Json) -Headers $Headers -Method POST -ContentType application/json
    if ($ExecutionMode -eq "Command") {
        $body = @{"script" = $Data}
        Invoke-WebRequest -Uri "http://$RouterIP/rest/execute" -Body ($body|ConvertTo-Json) -Headers $Headers -Method POST -ContentType application/json
} else {
    Write-Error "Could not connect to $RouterIP via Port #443! Service ""www-ssl"" already activated in RouterOS under /ip/services ???"
$tc.Dispose()
Save this code-snippet as “Invoke-MikrotikRestAPI.ps1” and enjoy :wink:
