Not sure what I may be doing wrong. The REST API does not appear to return scan results for wlan60- type interfaces, but the routeros command line does return results.
From the command line:
[admin@MikroTik] > /interface/w60g scan duration=5 number=*1
Flags: R - ROUTEROS
Columns: ADDRESS, SSID, FREQUENCY, SIGNAL, RSSI
ADDRESS SSID FREQUENCY SIGNAL RSSI
R 04:CE:14:FA:17:BF MikroTik 58320 100 -54
But no APs seen using postman or curl:
curl -k -u admin -X POST '> https://192.168.1.205/rest/interface/w60g/scan> ’ --data ‘{“.id”:“*1”, “duration”:5}’ -H “content-type: application/json”
Enter host password for user ‘admin’:
While for a wifi interface the REST returns results:
curl -k -u admin -X POST '> https://192.168.1.205/rest/interface/wireless/scan> ’ --data ‘{“.id”:“*2”, “duration”:5}’ -H “content-type: application/json”
[{“.section”:“1”,“address”:"08:B4:B1:D6:8F:70 ----- and a lot more was listed]%
Suggestions?
