REST API Translate
I need help :frowning: for some command in JSON where CLI like this - POST
/ppp secret set name=yyy numbers=[find name=xxx]
or another way for solving update data like that
Your help is very much appreciated..
You can run query with post
https://help.mikrotik.com/docs/display/ROS/REST+API#RESTAPI-Query
and then set
https://IP/ppp/secret/set?numbers=[find name=xxx]
{“name” : “yyyy”}
I tried it at postman, it isnt works.
advice me how to translate here
You cannot run find via API. Look at the link provided above which shows how to run queries
even though i put it inside query?
like this - POST body
{“.query”: [
“numbers=[find name=xxx]”
correct script way
/ppp secret set [find where name=xxx] name=yyy
extended syntax
/ppp secret set numbers=[find where name=xxx] name=yyy
First, GET the .id:
/rest/ppp/secret/name?name=xxx&.proplist=.id
(for example *5 )
Then PATCH that .id setting the new name:
/rest/ppp/secret/*5
{“name”: “yyy”}
Ok sir got it,
So we must do it at 2 step
Hope next we get more detail about REST :slight_smile:
Thanks for advice sir
I’ve tried patching on the ID to change the name but what ends up happening is that it creates a duplicate ppp secret entry with the name provided
