restore-config-from do nothing
I am try to copy config from another partition:
/partitions restore-config-from part1
Router say about copyinf, reboot and config don’t restored. What is wrong?
have found the same problem trying to do copy-config-to (it says it copied, but when it boots into part1 the config is ancient, and not the copied one).
definitely affects 6.44.5
