Restore configuration issue on same device
SXT G-5HPacD
Saved .backup file and restored into a new SXT G-5HPacD r2
Both machines 6.38.1
All seems ok, except wireless interface on the new unit is named wlan2 instead wlan1, it is disabled and radio parameters (band, channel width, frequency) NOT configured.
Is this normal ? Why ?
The .backup file is for use in the same device.
This behavior is normal.
From New Terminal type: export file=test in first router.
This command will create in Files the file test.rsc
Take this file and drag’n’drop it to the second router.
From New Terminal type: import file=test in second router.
