Restore default IPSec group
Hello.
I’m accidentally deleted default group in IP IPSec Group.
How I can restore it?
I can create new one, but I can’t set Flag to make it default (with asterisk) .
Try to disable IPsec in L2TP server and enable it again.
It appears to be still a problem so far, even on the latest firmware.
Disabling/enabling L2TP server does nothing. Furthermore, roadwarrior can’t connect because the dynamic peer has “policy template group” unknown.
This can be fixed by duplicating the peer and removing the dynamic one (which is read-only). This however works only until reboot.
I found no other way to create this group with the “default” attribute. I am not very positive about the “reset to factory defaults” approach
