Restore The Dude configuration
Hello everyone,
I have The Dude installed on a PC which won’t boot anymore. However, I can access the HDD’s data, so I have downloaded The Dude’s folder.
Which files should I copy over in order to have the configuration on my new PC?
Thanks a lot.
Just re-install the dude from scratch then overwrite the dude folder with your old folder from program files.
[edit make sure you install the same version…]
I just had to do this after an apparent Windows Update removed all .EXE and DLL files.
Tip: When you restore, don’t run Dude once. Just install, then restore.
