Restoring backup
hi, i have a couple Net-metal deployed, and when i restore a backup from the other, after reboot, wireless interface appears turned off, i would like to find a way of avoiding that, thanks in advance
should not use backup to restore on another device, if in network environment, you will end up with duplicate MAC’s, etc. Backup is designed to restore the device you backed up.
Rather use export via Terminal Window
