I am a new user to mikrotik .as i am using 450g v5.15 with simple queues and i want to restrict bandwidth to ip pool i.e
i am using Ether1 with different ip series
Ether1 :- 30.30.246.1/24
Ether1 :- 172.200.45.1/24
Ether1 :- 2.2.2.1/24
and i want to restrict bandwidth to Ether1 :- 172.200.45.1/24 (2MB) and other Ether1 :- 2.2.2.1/24 (1MB) so pls give a solutions
QoS Tree is easier…
Assuming you want to limit Internet Speed:
If not then you can make little changes to suit your needs
Change this one part “YOUR_WAN_INTERFACE” to your Internet Interface Name.
/ip firewall mangle
add chain=prerouting src-address=30.30.246.1/24 action=mark-connection new-connection-mark=Network30_conn comment="Network 30"
add chain=prerouting connection-mark=Network30_conn action=mark-packet new-packet-mark=Network30_PACKET passthrough=no
add chain=prerouting src-address=172.200.45.1/24 action=mark-connection new-connection-mark=Network172_Conn comment="Network 172"
add chain=prerouting connection-mark=Network172_Conn action=mark-packet new-packet-mark="Network172_PACKET" passthrough=no
add chain=prerouting src-address=2.2.2.1/24 action=mark-connection new-connection-mark=Network2_Conn comment="Network 2"
add chain=prerouting connection-mark=Network2_Conn action=mark-packet new-packet-mark="Network2_PACKET" passthrough=no
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name="Internet Download" packet-mark="" parent=global-in priority=1
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=2M name="172 Down Limit" packet-mark=Network172_PACKET parent="Internet Download" priority=1
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=1M name="2 Device Down Limit" packet-mark=Network2_PACKET parent="Internet Download" priority=2
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name="Internet Upload" packet-mark="" parent=YOUR_WAN_INTERFACE priority=1
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name="172 Device Up Limit" packet-mark=Network172_PACKET parent="Internet Upload" priority=1
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name="2 Device Up Limit" packet-mark=Network2_PACKET parent="Internet Upload" priority=2
Explanation:
- You must identify the packets in Mangle for each device or network you want to apply a rule or filter.
- Using the Packet Marks create the rules.
Enter this code via Terminal and then see it in the GUI, it will help you to understand how it works.
