Restrict SNMP to use V3 only
Hello folks,
i’d like to monitor a MikroTik device via SNMP over the public internet. I therefore would like to allow monitoring via SNMPv3 (with authentication and encryption) only.
As soon as I enable SNMP, I can query the device using all SNMP versions.
Is it possible to restrict querying to SNMPv3 only?
If not - what’s the idea behind implementing SNMPv3 as the more secure standard when SNMPv2 is still sending information unencrypted over the network?
Thanks in advance for your feedback!
You can use only SNMP v3 for monitoring.
More information about SNMP find below:
https://wiki.mikrotik.com/wiki/Manual:SNMP
Hello Elans,
thanks for your feedback. I already knew that wiki article and have read it - but I don’t see where it explains how to enable/ disable only certain versions of SNMP.
SNMP is either
enabled (yes | no; Default: no)
Am I missing something?
You have to configure “snmp community” (through GUI it would be IP → SNMP → Communities) where you will specify security, authentication protocol etc.
Detailed description about Community Properties:
https://wiki.mikrotik.com/wiki/Manual:SNMP#Community_Properties
