Hi All,
I need help from anyone that can disable/restrict at frequency mode to stick on regulatory domain or disable “advance mode” so we can not change frequency mode to superchannel. And also if there is any way to delete/disable few frequency that out of range from our frequency range, such as the range of certain country is 5730Mhz-5800Mhz but on the list it show 5725Mhz - 5825Mhz. So we need help how to delete 5730Mhz and 5825Mhz from the list?
Honestly, shortly i will have test to get certified certain minipci wireless from our communication ministry. But the problem is the range is too wide against our ministry rules so the option are disable advance mode or stick on regulatory domain or delete/disable few frequency so we are still in range.
Please advise. Thank you
