RESTRICT VPN ACCESS
I need to grant a vpn access for a user but I need to RESTRICT his access to certain IPs and certain PORTS. I’m using PPTP with PPP profiles.
Is that possible?
Regards
Hernán.
If you’re using PPTP you’re also using an IP pool to assign the remote user an address from. Use the firewall filters in the forward chain to permit and deny access from/to that remote address pool according to the policies you want to implement.
