restricting mobile phone access through the router
Hi
I have a PBX behind a Mikrotik RB2011 and it has been protected by restricting inbound NAT to Voip Provider IP addresses only so no need for firewalling the traffic as such.
They now want to have personal mobile phones of the staff use SIP apps (3CX system) to dial out from their extensions when they are on the go. Which means having to open the ports to public ip addresses which is obviously a massive security risk.
I would like to restrict the NAT inbound to MAC addresses of the mobiles or something like that. Anyone know if this is possible on the RB2011 or if there is another cunning way to lock NAT forwarding down to a bunch of mobiles and VoIP providers only.
thanks
I think using VPNs would be the best practice from a security point of view, though how will it perform will depend highly on mobile connections quality.
AFAIK you cannot restrict from macs when the mobile devices incoming connections come from internet; even if possible, as you know spoofing macs is a trivial thing…
