Hi all
Just wondering if anyone has seen restrictions with WDS with more than 9 unit loged in at a time?
Sarky
Hi all
Sarky
need more details in order to help. the more you put down the more likely people will help
Randy
I have an AP running MT 2.8.27 with WDS-Bridge and hotspot on 2 Wireless Card and i have noticed that It is only registering WDS1 through WDS9 and i have more than 9 WDS clients on the network.
My Question is, has anyone out there using similar setup achieved more than 9 WDS clients at the same time or is it a restriction/bug on the Mikrotik Side?
Thanks once more
Sarky
do you have more then 9 clients connected now . or is this something your planning?
i dont think wds has a limit.
randy
I dont know if this is actually a bug but you should do send a supout (consult documentation) and contact support@mikrotik.com
There have been similar bugs with other interface types before.
