Retrieving distance between wireless wire links constantly
Hi.
We need to collect information about the distance of two Wireless wire modules. It can be seen in UI and also I can fetch it with SNMP. But the problem is, that the distance stays fixed even when the modules are moved. I would need to have the distance updated very often, preferably even 5Hz.
Is there a way to tell to 60GHz devices to refresh the distance data constantly, several times per second?
Wireless wire, routerOS 6.46.4.
