Good morning / Good afternoon / Good night
I am a zabbix User, and I am monitoring my network trough it via SNMP, succeeded to the next problem, there is not OID for Rx / Tx CCQ.
My idea to solve the problem was to capture the data via SSH; More I can not only capture the Rx / Tx CCQ.
interface wireless registration-table print stats
interface=wlan1 radio-name=“xxxxxxxxxx” mac-address=xx:xx:xx:xx:xx:xx ap=yes wds=no
bridge=yes rx-rate=“180Mbps-40MHz/2S/SGI” tx-rate=“180Mbps-40MHz/2S/SGI”
packets=1098588698,657481190 bytes=2939352771,763916819 frames=181467646,492257965
frame-bytes=1633832134,1568929546 uptime=2d10h48m32s last-activity=0ms
signal-strength=-51dBm signal-to-noise=69dB signal-strength-ch0=-53dBm
signal-strength-ch1=-57dBm tx-signal-strength-ch0=-53dBm
tx-signal-strength-ch1=-58dBm
strength-at-rates=-51dBm@6Mbps 0ms,-51dBm@HT20-4 11m11s540ms,-53dBm@HT40-4 0ms
tx-signal-strength=-52dBm tx-ccq=99% rx-ccq=100% distance=12
routeros-version=“6.34.4” last-ip=185.60.216.22
tx-rate-set=“BW:1x-2x SGI:1x-2x HT:12” tdma-timing-offset=79 tdma-tx-size=4000
tdma-rx-size=4000 tdma-retx=1 tdma-winfull=2
To specify the item I’m looking for:
[ST_CENTRAL_LINK_5.8] > interface wireless registration-table print stats where rx-
ccq[ST_CENTRAL_LINK_5.8] >
And I tried several variations command and had not result different from above.
I hope someone can help me solve this problem …
thanks in advance!
OBS: OID for Overwall-CCQ don’t work !
