Reverse NAT or WAN NAT Redirection on RouterOS
Hi.
I just purchased my first RouterBOARD, RB951G-2HnD.
It’s very different than the routers I have used so far, and I have many, many problems to solve. But here’s the biggest.
For example, my RB has LAN IP “10.0.0.1”, WAN IP “10.20.30.40” and WAN domain “myhome.ddns.net
When a PC on the LAN with IP 10.0.0.100 types “myhome.ddns.net”, a “Connection Refused” error is displayed.
When the same PC is connected on the WAN with IP “20.30.40.50” and types “myhome.ddns.net”, the web server’s page is displayed.
So, I want to have access to my services from the LAN when I type my domain.
This feature was called Reverse NAT or WAN NAT Redirection on my old routers, and I had only to check a box to enable or disable it.
I think that in RouterOS it’s a bit more difficult, but I don’t now how to make it work.
Can anyone help me?
Thanks in advance.
Hairpin NAT
Thank you for your answer.
Found this http://wiki.mikrotik.com/wiki/Hairpin_NAT but I can’t understand how it works.
Here’s my network:
PPPoE Dynamic with example DDNS name: myhome.ddns.net
10.0.0.1 - RB951G-2HnD
Ports that have been forwarded on NAT:
HTTP Webfig - Port 9080
HTTPS Webfig - Port 9443
Winbox - Port 8291
10.0.0.10 - Server1
HTTP Sever - Port 80
HTTPS Server - Port 443
Apache HTTPS Server - Port 8443
If the PC is connected on another network and tries to access myhome.ddns.net, all services are available under one DDNS name:
myhome.ddns.net:80 - HTTP Server
myhome.ddns.net:443 - HTTPS Server
myhome.ddns.net:8291 - Winbox
myhome.ddns.net:8443 - Apache HTTPS Server
myhome.ddns.net:9080 - HTTP Webfig
myhome.ddns.net:9443 - HTTPS Webfig
Can anyone write me the code to insert on the terminal to configure firewall so this above happens on LAN also?
Thanks in advance.
Here you go, this should give you all required info to solve it:
