Hello
I have a 750GL that is driving me crazy.
I can neither connect and configure it NOR reset to factory defaults
I know the board is alive because i can see the dhcp requests from port 1 on wireshark(i’m using dhcp reserved static address) but i get no login page or anything when i try connect to that ip address, nor on the 2-5 ports trying 192.168.88.1 ?? In this instance no big deal , i’ll reset it to factory defaults, only i cant, or it wont
From the blurb ive read and video’s ive watched , i powered on the board while either holding the res switch in or shorting the pad on the motherboard BUT ..
In either instance the ACT/user led comes on, goes off, that’s it. It does not flash
I tried netinstall as per “https://www.youtube.com/watch?v=GIijZ6_i55g”
NOPE
any suggestions
thanks
