REVOKED CERTIFICATE STILL WORK
I have set up a OVPN server and i tested it with certificate, but when i revoke the certificate it steal work , what is the problem ?
i found that i should add
/certificate
sign ca-template ca-crl-host=xxx.xxx.xxx.xxx name=CA_OM
but i don’t know which adresse i should put in it.
Thanks a lot
crl host is where crl list will be stored. It cab be routers address, where CA is generated.
Thanks for your reply ,
the question is which adresse IP Public or Local or Remote adresse ?
Whatever address will be reachable by the client.
so if i have maked the router is the DMZ i will use a IP ADRESS PUBLIC ?
i have put in it the local adresse of profile VPN but not working the revoked certificate still work
