namo
June 28, 2010, 9:46am
1
I have Microtik v4.10 with hotspot user account.
In winbox,
In interfaces, I have Mybridge, ether1, ether2
ether1 is WAN
Mybridge is LAN and include ether2
I want to remove mybridge and let ether2 to be LAN. What the places that I need to change the setting from mybridge to ether2?
Note:Mikrotik setting was taken from device that have 5 Ethernet ports and four of them are bridged but I don’t need this
mrz
June 28, 2010, 9:51am
2
remove ether2 from /interface bridge ports
If you don’t need bridge at all, then remove bridge interface itself.
namo
June 28, 2010, 9:59am
3
no there are several places I need to change such as DHCP server and Hotspot
mrz
June 28, 2010, 11:45am
4
It depends on what was running on the bridge interface.
namo
June 28, 2010, 12:04pm
5
I told you that mybridge was LAN. what other things other than hotspot or DHCP server that related to LAN.
I think if there is rules in the firewall they will go by the IP address not the interface
what other places that you fill interface?
mrz
June 28, 2010, 12:13pm
6
As I already mentioned, anything that was configured to run on the bridge must be changed. And it can basically be anything firewall filters, queues, hotspot, pppoe server, vlans, vrrp, dhcp etc.
